2 ipod's on one laptop
Discussion in 'Headphones, Earphones & Portable Music' started by andytabor, Dec 23, 2006.
Tags:
  1. andytabor
    andytabor
    Jun 5, 2006
    1,446
    +35
    I currently have an ipod v5 video which i use with my laptop, ive also recently bought a new ipod shuffle, is their any possible issues or probs with using both ipod's on one computer or will they both sync ok? also by this i don't mean having them connected simultaneously.
    i have my video ipod set so i can manually manage the songs and i intend to do the same with the shuffle.
  2. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    No, you shouldn't have any problems.
  3. andytabor
    andytabor
    Jun 5, 2006
    1,446
    +35
    cool, thanks for the quick reply mate.:thumbsup:
  4. dkjc
    dkjc
    You should have no problems. I currently have 1 ipod and 2 shuffles linked to the same powerbook. no issues at all. In fact, when you first connect the new ipod, your mac should ask you for it's name., and this will then sync automatically or manually, your choice. Merry Christmas.
  5. andytabor
    andytabor
    Jun 5, 2006
    1,446
    +35
    cheers, merry christmas!
