2-in-1 DVDp or individual DVDp / CD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by richard76, May 10, 2005.
  1. richard76
    richard76
    anyone care to comment about price and quality when considering the purchase of
    1. DVD player that play CD audio as well as videos or
    2. standalone components eg individual DVD player and CD player
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Hi Richard,
    First of all, I think you will getter a better response in a different forum.
    Secondly, it depends on your budget and your current equipment. Over generalising, but if you are using a higher spec's projector, then I would be more inclined to use a "the all in one solution".
    If your display is more modest, then I prefer the two box solution. Provided your equipment down the line can take advantage of a dedicated CDP.
    As usual, no one solution fits all.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    As Harry says you won't get many responses to your question in the speakers forum so I have moved it here instead.
