2 identical PCI cards in system?
Discussion in 'Desktop & Laptop Computers Forum' started by Kramer, Aug 8, 2002.
  1. Kramer
    Kramer
    Anyone know how to run 2 identical PCI cards (Skystar 2 DVB - digital satellite cards), on 2 PCI slots in Win XP?
    Install one fine, install the second, during set up, the previous software needs to be uninstalled B4 it will install.
    Even if I uninstall the previous software, I see both cards in device manager (numbered #1, #2), - if I try to disable one the system restarts - I don't want to disable either, just trying things here).
    I know this is possible, but I'm told very tricky.
    Something to do with resource sharing, conflicts etc...
    Anyone know any work arounds, IRQs etc...
    I presume this would be the case for any PCI device, in Win XP or maybe even Win 98, ME etc...
    BTW, both cards (identical) would be using the same drivers & similiar software.
    Any input appreciated.
  2. mjn
    mjn
    May 24, 2001
    23,551
    Herts, England
    +11,966
    Assign a different IRQ to each PCI slot in the motherbpard BIOS. Also make sure the 2 PCI slots you are using don't share an IRQ, as any motherboard with 5 or more PCI slots will have at least 2 PCI slots sharing IRQ's.
