2 hopefully simple questions :-)
Discussion in 'Cables & Switches' started by Caimbeul, Sep 16, 2005.
  1. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    :hiya:
    Is it possible to extend a Coaxial cable without loss/degredation of signal? - I need to have my sky ariel extended by about 2 metres so my digibox can sit under the TV.
    Also can anyone reccomend any good component switch boxes? my main concern is signal degredation. Would need it to be able to handle 720p & 1080i (Xbox360 etc) but dont want to spend a fortune. Any advice is appreciated as I am new to switches. I have jeard that powered ones are better.
    Thanks for any help.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The answer to the first question is that it's certainly possible but isn't ideal. There shouldn't be a problem with your digibox if you use decent cable and connectors.
    Can't help with the second question I'm afraid. :)
