2 goes into 1
Discussion in 'Televisions' started by phillips321, Jan 8, 2005.
  1. phillips321
    phillips321
    Hi guys
    I have been looknig about lately and i have noticed that i can obtain two rear-projection tvs both of exactly the same model.
    they both have problems tho, the first set has 4:3 ratio screen burn and the second requires a new module. Are the damaged parts seperate so that i could take both TVs and combine the good parts or is the screen burn and the module the same thing?
    Cheers guys
  2. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Why would you want to mess about with a 4:3 old broken rear projection tv. Sounds a waste of time to me.
  3. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    i'd have to agree, would'nt touch them, you can get brand new for £599 43" rear projection
  4. phillips321
    phillips321
    the screen is a widesceen but has two dark bands at either side of the screen where it was used to display 4:3 ration images.
    The TV is a Toshiba 40PW13.
    Here is a statement about the first TV
    "This Toshiba (40PW13) 40" widescreen TV suffers from 4:3 ratio screen burn (where grey bars used to maintain the 4:3 ratio of older TV programmes have caused the left and right hand edges of the screen to become duller than the middle)"
    Can i combine the good bits from both of these tvs to give me one good one?
    I can get both together for around £100
    good deal or not?
  5. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    :suicide:
  6. phillips321
    phillips321
    so u think i should avoid this? Money is tight with me so i was hoping to get a large tv for the cash i have. I have seen the Toshiba that argos is doing, i cant justify spending £600 pound tho
  7. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    You wont get anything pleasant out of your little construction, I wouldnt evan pay £100 for it. Its not worth anything.
    If you got it for nothing give it a go, but I wouldnt pay for the privalige.
    Save your money.
