2 freeview boxes 1 arieal
Discussion in 'Freeview & YouView' started by wallzy, Jul 13, 2005.
  1. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    As the title really is ther any way of using 2 freeview boxes with one arieal if so what would i need
    thanks
    wallzy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you use a passive splitter, it will cut the signal to both boxes by more than half, so only advisable if you have a really strong signal. Best to use an aerial amplifer in the loft to feed the two outputs. They're mains powered, and can be fed from the lighting circuit, taking very little power. You can get amplifiers which get their power up one of the co-axial cables from a power supply downstairs.
  4. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
  5. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    hi
    ive daisy chained freeview boxes before with no problems, so i would try that first before you go buying things, if it has no rf output then the maplin splitter hd mentions will only loose 3 to 4db of signal so it may be worth trying that before an amplifier(save some cash).....
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Only 3 to 4dB ?
    3 to 4 dB is well over 50% :rolleyes: :eek:
  7. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    thanks for the info guys its not as easy as i thought it might be
    wallzy
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    -3dB is half power but digital doesnt need that much, i have split other diital systems using these units perfectly, they are the same sec as those used by the cable comapnies
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Agreed. As I said in post #3, it all depends on how much signal is there to begin with :)
    If I were doing this myself, I would choose either a 4 way aerial amp at £14.99 (part # 17158 from screwfix.com) or an 8 way unit at £26.59 (part # 33757) which would sit in the loft. The extra outputs on the unit would make the whole thing expandable for extra rooms, at just the cost of the extra cable and plugs.
  10. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,815
    Somewhere in South Yorkshire
    +5,025
    Signal strength is only a part of the issue. More important is signal cleanliness. All that strength gives you is greater resistance to external interference. If you have a clean signal, and little to interfere with it (properly suppressed thermostats in your fridge, little local traffic, for example) then low strength will not necessarily mean poor reception.
  11. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    just a thought would i be able to use a smaller arieal plugged into the back of the sky or does it have to be one of these big ones in the loft
    wallzy
  12. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    CABLE, CABLE, CABLE!
    Use decent quality 'digital spec' coaxial cable with foil shielding like that used by sat with as few joins as possible (i.e. NO wall plates).
    More info HERE
    The best place to put an amplifier is as near to the aeriel as possible, i.e a 'mast amp', which will mean ladders and roof :rolleyes:
    If you're not confident enough DON'T attempt it, get a pro in to do it.
    These are quality amps and not your cheap Argos ones that can sometimes do more harm than good!
    I have four TVs running off such a mast mounted amp with no probs.
