2 feet away
greyhorse
Im looking at an lcd screen to use for PC use mainly, i will be 2ft away would a 26" be better on the eyes than a 32".
LT26DX7BJ or 32 JVC's look really nice, did someone say they wont about to full screen mode on the pc input??
matJ
From 2 ft away a dedicated PC LCD monitor would be better, i would have thought! the resolution supported will be higher and compatible with a 1:1 image from the graphics card, as this is what they are designed for.
Have you tried a 20"/24" widescreen LCD monitor from 2ft away? Maybe youd be ok with that instead.
If you watch films/HD samples with the PC then bigger is better, as you sit further back.
dllord
Dell do some alright 24" monitors!
greyhorse
yeah but at 700 quid for a 24" they can keep it,
Least if I get bored with the big screen for the PC it can be used in another room.
badbob
At 2' distance you're looking at a PC monitor. A 20" widescreen 16:10 PC monitor is around £350, higher resolution than a hi-definition LCD TV (766 x 1060 vertical)
