2 DVI devices, one projector
Discussion in 'Projectors, Screens & Video Processors' started by AndyFov, May 7, 2005.
  1. AndyFov
    AndyFov
    Nov 20, 2002
    1,472
    March, Cambs
    +45
    I've a Sony HS10. I've a HTPC, and was planning on using that to network to the 'net, play MAME games, and install a WinTV card, I can connect by DVI.
    I also have just bought a Yamakawa DVD player with scaled DVI output. I figured the functionality of this beats using the HTPC as a dvd player - BUT, that's got a dvi output too. Is there a simple and cheap work round for this? Ideally, I'd like a box with 2 dvi inputs and a switchable output.
    It's my fault, I had assumed the pj had a DVI input and a 15pin Dsub connector, but it hasn't. Any ideas? Or should I just sell the Yamakawa and use the HTPC for everything?
    TIA
    Andy
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    You can get a DVI switch but they are pretty expensive for what they are.
    This chap on eBay is a good source...he is cheap and reliable:
    He offers both the Dtronics model
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=73387&item=5771564360&rd=1&ssPageName=WD2V
    and the Gefen version
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=73390&item=5771564730&rd=1&ssPageName=WD2V
    or if your not bothered about HDCP then he offers this cheaper model also
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=61396&item=5726168430&tc=photo
    Cheers, Lee
  3. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    I have the first one Lee links to above and it is an excellent piece of kit and works like a charm. Highly recommended.
  4. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,554
    Bridgend
    +118
    Hello Mate,
    Try Joe at
    http://www.tmfsolutions.co.uk/
    Sorted me out for a cable and I think he was planning to start selling switchers.
    Cheers all
