2 Computers....
Discussion in 'PC Gaming & Rigs' started by sniperkid, Oct 13, 2005.
  1. sniperkid
    sniperkid
    Sep 23, 2005
    39
    Ok this is sort of about gaming.
    I have a computer up stairs and a computer down stairs, i have Tsicali ADSL broadband (1 modem on each computer and they both have filters in them) but i can only connect 1 computer to the internet at the same time, is there a way i can have both computers on the internet at the same time without having a LAN or wireless network or any other type of network ?
  2. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    Basically no unless you get 2 adsl lines. You need a router of some sort or connect both computers together with a cross over cable.
  3. Darko
    Darko
    Apr 13, 2005
    4,220
    Caterham on the hill Surrey
    +223
    go wireless bud and then you can share the broadband
    Darko
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Just buy a wireless router and some wireless network cards or USB network adaptors.
  5. sniperkid
    sniperkid
    Sep 23, 2005
    39
    im going wireless when i can afford to :thumbsup:
    Thanks Guys
    ~SniperKid~
  6. branny
    branny
    Feb 26, 2005
    3,693
    103
    Pie Land
    +274
    Scan usually have some great package deals on Wifi, usually the KCorp stuff. I have this and it is really good.
    Branny
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    I have a router, with my downstairs pc connected via straight through ethernet cable. Don't trust wireless routers, tried one and got too many dropouts. :thumbsdow
  8. GJC
    GJC
    Mar 1, 2002
    2,143
    London
    +69
    Wireless will be fine (no dropouts) so long as you look at this type of system:
    Netgear
    Reviews back it up too.
  9. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    Londoner living in Bahrain
    +140
    If you have to be really cheap (and the performance ain't so great), then you can look at USB wifi dongles. They work well just not that fast.
  10. sniperkid
    sniperkid
    Sep 23, 2005
    39
    ok i have a JAHT Wireless ADSL Router (WAM-2104P) and i cant figure how to set it up with the help of a quick guide and the full one (which i found online). This is wat i have done atm;
    1. I have put the RJ-111 Cable from the phone line to the router (yes it is through a filter).
    2. I have the LAN (Ethernet) cable from my PC to the router.
    3. I have put the PCI card into a PC downstairs and i have installed it with the CD-ROM which was included.
    4. I can connect to the router from the PC downstairs (http://10.0.0.2) but i cannot seem to connect to it from my PC (which has the router connected via LAN port).
    5. The power, TP1 and ADSL lights are on (not flashing) and the WLAN light is flashing.
    6. None of the computers can seem to connect to the internet.
    7. I have tried creating a network and then trying to find it on the PC downstairs but no luck.
    Any *easy to follow* guides available (been tryin to get it working for the past 4 hrs :confused:)
    ~Sniperkid~
  11. sniperkid
    sniperkid
    Sep 23, 2005
    39
    Sorted! i have to say that the guide was very confusing as i have never worked with routers before but i got it to work now.
    ~Sniperkid~
