2 Coaxial TV leads to 1 input
viperfire
I have an LCD TV with one coaxial input that is used by my sky box downstairs. My TV also has an integrated freeview box that I want to use when sky is being watched downstairs and so I need to connect the main outside aerial to the TV as well. How can I do this so that I can watch one or the other without using a switch box? My TV has a spare scart and s-video input if it helps.
viperfire
Anyone? – I have been all round the internet trying to find something that works but to no avail – is it impossible?
ebony
Why have a coax going into sky box, unless you need it for recording analogue ?
Otherwise Aerial to sky box, RF2 on sky box to LCD TV upstairs, bit of a pain to run the cable. You may need a booster before the signal goes into the LCD.
Using this method you will be able to watch analogue, freeview and sky upstairs.
