Question 2 channel amp for marantz 7009
Discussion in 'AV Receivers & Amplifiers' started by Scott76, Jul 7, 2015.
Tags:
  1. Scott76
    Scott76
    Jan 31, 2013
    1,363
    63
    +120
    Hi all,
    In a bit of a dilemma as I'm looking for advise on what make and model of two channel amp I should be looking for the partner the marantz 7009 or 7010 to give me 7.1.4.
    I'm not sure weather to wait and spend on the 7010 or get the bargain 7009 now as I won't use anything 4k until we have a 4k projector for under a grand,if there ever will be such a product!.
    So I could spend three to four hundred on a second hand 6 channel or a hundred on a two channel as there seem to be a load of them on ebay,problem is I have know idea what I'm looking for or how to connect and set them up so would really love some advise please.
    Ideally don't want to spend a lot as still got to buy the receiver and extra speakers.
  2. Scott76
    Scott76
    Jan 31, 2013
    1,363
    63
    +120
    Anyone?
  3. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,149
    2
    Normanton
    +6,454
    yes
    the Marantz MM7025 is a cracking amp and partners the 7009 perfectly, also you need to be quick if you want to get the 7009 as I understand they are getting thin on the ground
    I`ve used them quite a few times in Atmos systems and it really is the one to go for if you want everything to match up as well
    Allan
  4. Scott76
    Scott76
    Jan 31, 2013
    1,363
    63
    +120
    Cheers,I have read a lot about the new nakamichi amps which are getting rave reviews for 400 quid!.
  5. mtenga
    mtenga
    Jan 27, 2013
    8,290
    3
    Beckenham
    +2,259
    If you do that be quick. I believe their price is going up at the end of July. I glanced the thread in the power amp section the other day.
