2 centres instead of 1?
Discussion in 'Cables & Switches' started by NEXUS-6, Oct 29, 2004.
  1. NEXUS-6
    NEXUS-6
    Oct 28, 2004
    10
    I have a problem with positioning a centre speaker because of a sofa being beneath the projection image. The two fronts are fine either side of this sofa but there is no chance of my wife letting me wall-mount a centre speaker beneath the screen. If possible I would like to split the centre channel between two smallish, pod-ish speakers mounted on top of each front speaker but I'm not sure what the effect of wiring two speakers in parallel to the centre channel of a receiver/amp would be and what would it sound like.
    Is this possible? Any suggestions? Am I being stupid? What speakers (cheapish) could I use?
  2. Cmoth
    Cmoth
    Apr 21, 2004
    1,150
    38
    Hertfordshire
    +22
    if you want my honest opinion, i think your being stupid! - If i were you I would do away with the centre, if its impossible for you and the Mrs to agree a compromise and set your amp to no centre speaker.
    A even less preferred option may be to utilise the speakers in the TV as the centre speaker but I would imagine their quality ( or lack of) would be highlighted by your side speakers ?
    I have never tried two centre speakers and you run the risk of overloading your amplifier due to the recommended ohmage etc. I dont tecnically know enough about this other than knowing you need to check it out. Im sure someone on the forum more technically minded can elaborate further on this point.
