2 centre pre-outs?
Discussion in 'AV Receivers & Amplifiers' started by tomson, May 13, 2002.
  1. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I've been using 2 Rotel power amps (in bridged mono) to run the front speakers on my system. In a moment of boredom i decided to try running the centre channel through one of them and noticed there are 2 centre pre-outs on my Yamaha amp.
    Why are there 2? Is it so I can run 2 centre speakers?
  2. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Yes it is so you can run 2 centre speakers, although this seems funny its sometimes better to have 2 centres if you have a large screen e.g. spreads the sound more evenly across the screen than 1 speaker can. I guess it would only really matter on widescreens 46" or bigger.
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    Running two centres can have all sorts of problems with acoustic cancellations and can be difficult to set up properly, best avoided to be honest.
    A decent centre speaker (or speaker that matches the front pair), setup properly should be all you need.
  4. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Cheers for the replies. Cant say i've any need to run 2 centres with my miniscule TV. But at least now I know.
    Just out of curiosity... what would happen if I took one pre-out into the power amp's left channel and the other into the power amp's right channel and ran the power amp in normal stereo mode?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You can use it to biamp the speaker, perhaps a good idea for your center: use the two pre-outs and wire one terminal of the center speaker to the L out of the poweramp and the other one to the R out. Given of course your center allows biwiring/amping.
