Hi all
Complete noob here saying hi and hoping to benefit from your collective expertise.
I’m doing my research to set up a new system in my tv room. The room is 185 sq feet/17sq m. Wooden floor bay window one rug etc.
The tv is a new 43 inch Sony xf85 series. I have a a sat tv box, DVD player, Apple TV and Nintendo switch I want to integrate. I also listen to a fair amount of music via cd, and stream Qobuz. Any system will be shared with TV movies music and gaming.
So I have a system query.
Option 1 is feed my sat box,dvd,atv and switch all into my tv via hdmi and then go optical out into a pair of kef lsx and then go sub out from the kef master into a rel t zero.
Option 2 is feed all sources via hdmi into an av receiver then go hdmi arc into tv and then have wired speakers coming from the avr. The sub would also be wired to the Avr. Two avr I’m looking at are the Yamaha RXS602 and Sony are dn 1080. Possible Speakers are kef LS50 or monitor audio silver 50 or dynaudio emits.
So like I said any system will share duties with TV movies and music. Option 1 the kef lsx has minimal wiring,is Roon ready,Bluetooth etc but if I want to put on a cd or stream I would need to turn on the tv(I think). Also my understanding is that lfe sound effects won’t be transmitted/sent to the sub so losing out on the rumble in movies but will work fine with music.
Option 2 is also Roon Ready via AirPlay Bluetooth etc but involves running speaker wire in front of my inset stove fireplace(wife complaints!) but would allow lfe sound wffects to be sent to sub. Also I wouldn’t need to turn on the tv just to playa cd or stream some music.
So which option might better serve my situation. Or what other set and components would. I note on the Sony avr review here the reviewer stated that if all you are doing is 2.1 then there are better options. What would those be?
Would the Yamaha or Sony be powerful enough to power the passives to a good level and be able to match the lsx 100w per speaker?
Also and this might swing it-if I go with Yamaha or Sony is it possible to intergrate their respective wireless speakers into a 5.1 set up with the avr powering passives as well. A mix of wired and wireless speakers if you will and if so has anyone actually done it and does it work?
Any other suggestions tips and considerations greatly appreciated.
Thanks in advance to all who contribute
