1st Home Cinema Kit
Armalig
Looking some advice from you experts in this Home Cinema game.
I have a 32" TV hooked up only to a std SKY digital dish. (no aerial connected etc) Was looking for DVD Home cinema kit to complement the std nicam sound from box. Pro-logic II I`m told converts nicam into the separate sound channels and sounds the biz ...?
Also I am assuming that all channels viewed thru my SKY setup could be therfor brought to life with this PLII option...
THinking of Panasonic SCHT900 . Have not read any bad reviews yet for this --ANy comment? ROom is farily big -approx 7 *4 meters Like good bass ...etc. Have around £400
Any suggestions or helpful info much appreciated...
S
Skeeter
No expert more of a beginer like u but im in a similar position, have 28inch ws tv and freeview and im going to get the LG LH-D6530, it has all the features like dts, dpl2, dolby. It has 350W Total RMS output which is 5x 50w RMS satalite speakers and a 100W RMS subwoofer. I have a largeish room too and this should fill it nicely a friend oif mine said which knows about these things. Room is like 18x12 ft aprox.
Either this system or the panasonic scht500. If i had 400 to spare id try to get best all in one system so go with the 900 if u think its best.
Armalig
thanks for info
Can anyone reccommend a site or link to detail the setup of DVD cinema kit. eg Wiring --Best location for different room layouts etc etc
Also i want predominantly to use the sound as PLII for my SKY package (not much DVDs ) what way does the cabling work....do i plug from DVD player to some terminal on digibox?...HELP!!!
