1st HC Setup options - Opinions/Help please (Mission/KEF)
Discussion in 'Home Cinema Speakers' started by JD20, Jul 24, 2003.
  1. JD20
    JD20
    Jul 22, 2003
    32
    After putting it off for years I've finally decided to bite the bullet and setup a home cinema system in my bedroom.
    Looking around the sheer number of choices available are overwhelming so I'd appreciate any comments/criticisms on items I've narrowed down for a shortlist.
    Budget would be an absolute max of £1k but if I can save a bit the better.
    My room is a fairly reasonable size, and while floorstanders and standmount speakers would be fine, I really like the look of the KEF Eggs, and all comments I've seen look to be very very positive. My only concern is are they really THAT impressive ? Can they fill a room and make it come to life ? I realise a demo is in order, but just how good are they ?
    The Denon 2802 I dont really know much about (just started looking), but for an ALL-IN package, I thought the one above looked pretty good (but what do I know !)
    Would there be a better alternative ? Are there any bottlenecks ?
    Would the KEF setup be significantly better than going the way of Mission ?
    Both ideally I'd like to demo, its just a completely coincidental opportunity has arisen re: the KEF's in that I'll be staying VERY close to Creative Audio next week and they can only be bought in person....
    PS:
    Will be demoing the KEF's on Friday. 1st demo session, woo !
    Anything i need to know ? Suggestions ?
  2. JD20
    JD20
    Jul 22, 2003
    32
    Just seen that the Denon AVR1803 has a deal making the KEF setup £888.
    Anyone have any experience with the 1803 vs 2802 ?
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Do a search. Those speakers are THE most discussed units on this forum. There are also plenty of threads on all 3 amps.
    (Search button is top right of all pages)
  4. JD20
    JD20
    Jul 22, 2003
    32
    Discovering that as I type, this could take a while :D
