1gb drag & drop recomendation please
Discussion in 'Headphones, Earphones & Portable Music' started by Darthvador, May 2, 2005.
  1. Darthvador
    Darthvador
    Jan 25, 2005
    58
    paignton
    :) Can Some one recomend me a 1gb mp3 player which is drag & drop and not relient on software to transfer to the machine and is small & cheap and light weight and most important sounds good :D
  2. paulfoley
    paulfoley
    Sep 17, 2003
    3,507
    Hants
    +112
    Ipod Shuffle? Its cheap, its getting good reviews at the moment, looks cool & is about as easy to use as toilet paper.
    :thumbsup:
  3. Darthvador
    Darthvador
    Jan 25, 2005
    58
    paignton
    :) Looks good do you have to have itunes installed or can i just drag and drop on a clean system :)
  4. jamesb
    jamesb
    Jan 29, 2002
    15
    the creative muvo n200 is pretty good too.. can just drag and drop files to or from it using windows explorer. it also has a radio and comes with an arm-band thing and has a small display.. so a few extra bits and functionality that the shuffle doesnt have.
