1971 Porsche sub ?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by MarkEmmett, Jul 19, 2003.
  1. MarkEmmett
    MarkEmmett
    Anybody out there got any suggestions of where to put a small sub .
    Thanks Mark
  2. Dave20
    Dave20
    hi, well porsche is pretty vague heh.. i can only assume its a 911. if this is the case then most 911 owners put a sub at the end of the pessenger footwell (10inch) due to these being extreemly long footwells. i must admit though i have never worked on one that is quite that old so not totally sure if they have the long footwells of its later models.. if it isnt a 911 then i have no idea hehe
  3. MarkEmmett
    MarkEmmett
    Hi there dave Thanks for your reply and you were right it is a 911
  4. Dave20
    Dave20
    well, not sure on the depth of the footwells in a 1971 911, but i have seen such builds in 1985 -1992 models. you can buy 10inch woofers that demand a tiny space for a box and so long as you had a good grill on the front it wouldnt get booted by your pasengers.
    i myself have installed subs to a 911, but this was a 1998 RS 993 so a bit hard to compare as there was no "backseat" in that :)
