1910 widescreen 4:3 output
Discussion in 'AV Receivers & Amplifiers' started by gcook, May 16, 2005.
  1. gcook
    gcook
    Mar 9, 2005
    9
    Just recently bought a 1910 as an entry in digital viewing to go with a Philips 32pf9986 LCD.
    When I have the output from the 1910 set to widescreen I get what I expect but when set to 4:3 the picture is even narrower where I would have expected it to fill the screen more.......
    Relatively new to this medium so any assistance in getting the screen a bit fuller would be appreciated.
    Also would appreciate any advice on best value dvid to dvid cabling (2m only).
    Cheers.
  2. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    It depend on your screen. I'm guessing it is a 16:9, so this is the setting to us. Not all films will fill the screen depending on the aspect ratio.
