1910 firmware
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paulxxiii, Dec 21, 2004.
  1. Paulxxiii
    Paulxxiii
    Nov 20, 2004
    26
    Hello everyone,
    Do any of you folks know anything about the latest firmware (1.10) for the denon 1910 to make it multi region, i got my player and was told i would recieve the disc soon as it was not at the shop at the time of purchase, does anyone know where i can get my hands on it.
    cheers.
  2. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    The 1.10 firmware is nothing to do with multiregion. The multiregion hack is separate and should be available from most suppliers by now - I had mine done a few weeks ago.
  3. leoncino
    leoncino
    how do I even check which firmware the 1910 runs on?
    leon
  4. svrmarty
    svrmarty
    Dec 16, 2004
    13
    press "1" "2" "3" "4" on your remote control and then press
    "Display". your tv should now display your current running firmware
  5. svrmarty
    svrmarty
    Dec 16, 2004
    13
  6. Prax
    Prax
    Considering buying the 1910 to use DVI output on my plasma which is HDMI Pioneer any good? I also want to make it multi region?
    HELP
  7. svrmarty
    svrmarty
    Dec 16, 2004
    13
    i haven't found any MR firmware for 1910 to download.
    you can buy the MR firmware in ebay (found some for code2 1910)
    my advice is to buy it codefree
  8. leoncino
    leoncino
    I got firmware 1.11
    Is there any information on what's different in each firmware?
    And to those of you who got a MR 1910: did you do it yourself or did your supplier sell you a MR version?
    TIA
    leon
  9. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    My supplier did mine a couple of weeks after I bought it.
  10. svrmarty
    svrmarty
    Dec 16, 2004
    13
    did anyone get the firmware as file to flash it by my own ?
    i've only 1.10 code2 firmware
  11. leoncino
    leoncino
    too bad I don't
    would need the 1.11 file as well...
    Anyone?
    And, BTW, what's the most recent FW version?
    thanks
    leon
  12. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    I've heard of a 1.12
  13. joerg.batterman
    joerg.batterman
  14. J_P_P
    J_P_P
    Hello,
    Is this uptade just a multi region patch (just for user with already the firmaware v 1.12 ) ? or a update from previous version to v 1.12 ? :confused:
    My question is i already have a older version of the firmware, but my player is Region free ...if i apply this, will my player have v 1.12 of the Firmware AND wil it still be region free ??? :rolleyes:
    I have v 1.10 ... what will i gain (if anything ) with this upgrade ?
    Thanks in advance
  15. Maxi_TK96
    Maxi_TK96
    Mar 31, 2004
    117
    16
    Helsinki
    As far as picture quality goes (macroblocking) there was no apparent improvement with 1.12. I had the same situation like you meaning having an already MR 1910 and the upgrade didn't change that fact (=player still MR). Unless you think that there is something really wrong with your player you might be better off not doing the upgrade because it can mess up your player if the upgrade process goes wrong.
  16. J_P_P
    J_P_P
    Guess i won't be upgrading then :rolleyes: ... i woulkd consider if it improved the image ...but in this case :nono:
