19" TFT Monitors... which of these 2 would you go for chaps...?
Discussion in 'LCD & LED LCD TVs Forum' started by stevedster, Feb 16, 2005.
Tags:
  1. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
  2. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Probably the wrong Forum for PC monitors, but I would choose the Viewsonic out of the 2, simply because the Viewsonic had both D-Sub (horrible Analogue) and DVI (Glorious Digital) most people run there LCD monitors through analogue D-Subs, I have a 19" & 17" LCD's and have tried the DVI adn D-Sub on both, and believe me once you see the difference, theres no going back.
  3. CraigKORE
    CraigKORE
    Without a doubt get the Viewsonic VX912.
    I got one after a lot of research and just over a month ago and paid 360 notes. Even at that price it was worth it as the picture quality is the best I have seen from a TFT LCD. Pin sharp detail, amazing colour, excellent blacks and no 'ghosting' from any games or DVDs I have played on it. Got mine from lowestonweb who now have it for 299 delivered, no dead pixels either.
    One of my better purchases - go forth and buy... :thumbsup:
  4. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    thanks for the advice, I will defo go for the viewsonic based on what you have said ! looks like a cracker of a monitor :D
  5. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    i got the viewsonic at home in 17" flavour, and it far better than any of the TFT's we have at work... definalty recommended
  6. osbornej76
    osbornej76
    I have the 17" VP171. Amazing picture. Don't even think about NOT using the DVI, analogue just doesn't cut it.
    I use mine for high detail Photoshop work and also playing games like Half Life 2 etc.
    Just make sure you graphics card is man enough to drive the high resolution for your applications.. and has DVI out!
  7. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    OK guys was all set to order that one, but this baby had just thrown a spanner in the works...
    19" Hyundai ImageQuest L90D+ 8ms Silver/black 700:1 con. ratio
    [​IMG]
    http://www.microdirect.co.uk/productinfo.aspx?productID=8533
    Anyone got one or any advise? Appears to be technicall the best one, but want to make sure before blowing £300+ on one, cheers.
  8. machinehead
    machinehead
    Sep 5, 2004
    468
    Greenock
    +15
    i have the lg 915 and it is great.it does'nt have a hdi input but it serves my needs perfectly.excellent for games.if you're not sure look around.
    regards machinehead
  9. machinehead
    machinehead
    Sep 5, 2004
    468
    Greenock
    +15
    regards machinehead
