19" racking- anyone use them for yer kit?
Discussion in 'AV Receivers & Amplifiers' started by nathan_silly, May 13, 2003.
  1. nathan_silly
    nathan_silly
    Ok not sure if this is the right forum...
    Thinking about replacing my Ikea Oppli TV Bench with a 19" racking system. It'll take up less floor space- and everything will go vertically.
    For example this guy..
    http://members.tripod.com/~BassPig/
    I have about 11 items (two more items in the future planned)
    Any comments appre. and rough costs, what comes with the kit, hidden costs, extra shelving etc.
    Cheers.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    Costs involved nathan ...
    The actual rack - you will probably want one with front and rear vertical supports.
    Shelf for each item without rack ears (the MC1 may have rack ears ... the rest probably wont). Decent strong shelves will cost from about £50 - £100 each.
    Blanking panels for the gaps between units ... will want to leave a 2u gap between most things.
    Hope this helps a little.
  3. DEO
    DEO
    So: for 11 items are we talking about nearly £1000
  4. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    the rack in the link looks like mid atlantic racking to me - not cheap stuff. it is very good though a cooling system would be reccomended for it, can't see any change out of a grand though:eek:
  5. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    alternatively, have a look at the Docent range at Ikea. I can't find a UK web site link, but here's one for the US web site:
    http://www.ikea-usa.com/product_presentation/subcat.asp?id=6062
    Look at the 21" shelf unit. You can buy an extension unit to make it about 180cm high. Just like most things in Ikea, it's very reasonably priced though you may want to modify it a little.
    Taimur
  6. mjn
    mjn
    May 24, 2001
    22,241
    Herts, England
    +10,086
    19" come in a variety of heights, from about 22U to 48U, and should cost around £400. Then depending on how neat, and what features you want, you can get sliding shelves, non-sliding shelves. Your best bet is speak to a PC network supplier.
  7. nathan_silly
    nathan_silly
    Cheers for that Taimur. Not sure whether a high & thin Ikea unit is strong enough really since it's made out of chipboard.
    I'm not buying the Crown K1 now- so all my units will be standard size. 450mm width x 400mm deep. Something like that Docent will be perfect, if it's solid wood.
  8. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    Do Ikea UK do the Docent range? I've not seen it before. I'm looking for a reasonable cabinet with glass doors. I'd really like to put a door on the back for easy cable access. I guess some bracing would be needed to stop it wobbling. I'd also put some ventilation in the door e.g. metal mesh.
  9. nathan_silly
    nathan_silly
    Not sure if Ikea still carry Docent, but my 2002 catalogue has the Docent range. Page 78.
    Just had a look on Ikea UK site, Docent range is no longer stocked.
  10. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    The Docent range is definitely available in the Glasgow Ikea.
    Taimur
  11. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    Dell do some nice racks.
    Have a look on their website :D
    Steff
  12. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    I've got the 2003 catalogue in front of me now and the Docent range is in there.
    I was also in the Nottingham store about a week ago and it was on display in there too.
  13. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Dell have a massive web site - any clues as to where to find the racks?!
  14. Gridlock_UK
    Gridlock_UK
    I'm just in the process of fitting my new AV setup into Docent cabinets. My hifi has been fitted in Docent furniture for the last year.
    The cabinets are very sturdy despite their construction material.
    However, beware! My shiny new Marantz SR4300 did not fit very well once cables were connected to the unit - although all other components fit fine. I ended up having to cut a slot to expose all audio & video ports at the back of the cabinet. However, I think this will help somewhat with cooling as well.
    Apart from this, the Docent furniture has been a fine home for my stuff. The single width cabinets fit standard-size hifi components and the double-width fits two side-by-side (just).
    Regards
    Gridlock_UK
  15. flat spot
    flat spot
    Dec 30, 2002
    447
    +44
    I'm no expert but shouldn't 'bass pig' have saved some money for a bigger telly?:rolleyes:
  16. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    Gridlock_UK,
    What did you do to allow you to get at the back of your gear?
    My plan is to have the 'rack' positioned so I can get around the back without moving it.
  17. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Gridlock
    I was thinking of buying a Docent cabinet and not assembling it with the back panel to allow wires to go in and out. Do you think that would compromise its structural rigidity?
    Taimur
  18. nathan_silly
    nathan_silly
    flat lock- widescreen is still pretty much a niche market in the US- most people just have 4:3 sets.
    Anyway, I dread to think how badly all them drivers effect the image (nice and purple!)
  19. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    Taimur,
    In my experience of Ikea and other self assembly furniture, the piece of hardboard on the back is essential to stop it all falling over. If you look at most 'backless' shelves there will be some sort of cross-bracing. This should still allow easy access. I want a door on the back to keep it tidy, but I think I'll have to brace it as well.
  20. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Thanks for the reply. I just read one of your previous threads and thought I'd throw this bit of information in for you too. Ikea also make a product called the Kaxas cabinet (the second A has a small circle on the top of it!). It's only available in a metallic "effect" grey colour, but it has nice smoked glass windows. If you want to see one without going to Ikea, apparently it supports the TV in the film "The Ring".
    It looked quite nice in the Glasgow store, it's just the wrong colour for my living room
    Taimur
  21. Gridlock_UK
    Gridlock_UK
    Steev
    I have my kit in unit about 4' x 4' which is stand-alone next to my TV. This means I can slide it out at an angle to get around the back. Not something that would work if you are using some of the larger Docent units! Previously I had no rear access at all before I got my AV receiver.
    Taimur
    The back panels are nailed in and keep the whole thing square, but not weight-bearing.
    Gridlock
  22. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    Taimur,
    I think I've seen the Kaxas and it looks pretty horrible. It really needs to have a wood finish to fit in.
    I may just ask our chippie to make something. It may cost more than Ikea, but it's the only real way to get what I want/need.
    I just need to work out all the dimensions, allowing for ventilation around each item. I'm also thinking of some trunking in the back to tidy the cables. Power down one side and signals on the other.
    All this is still a couple of months off as the new house isn't finished. See my site for pictures.
  23. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    I went to a cabinet maker and gave him some dimensions and specifications (and a design from an italian range of cabinets!). He quoted me £890 :eek: +VAT
    Taimur
  24. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    I don't know if it's of any help but some B&Q stores in the South of England (I don't know about the rest of the country) have a range called the "it solutions" range.
    These units have now been discontinued and are going pretty cheap if you can find any of them. The cabinets have a solid (veneered) chipboard back which you'd need to drill some holes into but overall they are very solid cabinets.
    I'm just in the process of replacing my IKEA cabinet (can't remember the name) with these B&Q units because they are much deeper.
    Also, you do need to be careful with IKEA cabinets to ensure that they are wide enough to get full size kit into them. Much of the stuff that IKEA sells has shelves that are too narrow to get full size kit into. My current IKEA unit is 440mm wide and will only just take regular kit. I've had to take the end cheeks off my JVC D-VHS machine to get it into the unit.
    Nathan ...... I just had a look at the photos you posted with your original query. With speakers like that, I'm surprised that the owner can get a picture on the TV. I've got a 1960's pair of Acoustic Research Ar-3s (sadly not Ar-3a) which sit at either end of an Ikea Oppli (?) bench and I get picture staining from the magnets on my 4:3 Barco monitor if I'm not careful.
    Brian
