Quantcast
18650 Battery runs out so quickly!
m1stergeorge
So I’ve got a couple mods that have different methods of power:
Innokin MVP4 (in built 4500mah battery)
Innokin Atlas Big Box (2 x 18650 batteries)
Vaporesso Armour Pro (1 x 18650 battery)
Obviously the Vaporesso isn’t a fair comparison as it runs on one battery but the difference in charge after a day between the Atlas and MVP is crazy. The MVP will easily have half a battery after a day of heavy vaping. The Atlas though will be on the verge of running out in the same period if not already flat. Generally I vape at 55w give or take so not a high wattage user.
As well as this, the 18650 batteries are allegedly 2500mah a piece. I use Efest Slim K2 intelligent charger - Evapo Online Vape Shop to charge the batteries and I’m wondering if that’s my issue. Anyone else had similar experiences?
GMC79
Mayb time to try a new battery, I've got a Sony vtc6 3000mah in my Asmodus colossal And it's incredible how well it lasts at around 45w. All day easy. Quite an effecient mod apparently even when gets low still seems to give the watts but still.
Badar
Which batteries do you use?
Hope they’re not efest batteries though. As they’re rebranded and some have false ratings on them.
m1stergeorge
Nah I think they Samsung 25R jobs. Gonna try some new ones when I get round to ordering them. I’ve heard good things about Fogstar so will grab a few from there.
Badar
Use the discount code “planetofthevapes15” for a 15% discount there. Also, they run promotions every Friday with discount codes (sometimes 20% too).
ctoom
Efest is good enough for vaping, I think the problem is the resistance of the Vaporesso mod
Similar threads
