180m cable run help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tmsjns, Feb 23, 2014.
  1. tmsjns
    tmsjns
    Aug 2, 2012
    So I have a cable run of 180m from dish to box and its been working fine until recently, As its not a standard install sky said they wont touch it so im going to have to replace the cable myself.
    my question is, Im going to buy 200m of wf125 and split that in two then the extra bits will be wf100 with inline signal booster at the joins, will this work or should i just fork out the extra cash and get it all wf125?
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,170
    Would it not be easier, cheaper and more reliable to install a second dish a little closer?
  3. tmsjns
    tmsjns
    Aug 2, 2012
    the only place i can get any signal is where the dish is now, I live on the side of a tree covered mountain on north wales and the dish needs to point over the mountain!
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
  5. tmsjns
    tmsjns
    Aug 2, 2012
    Www i didnt think of that, but how would it be powered?
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    A single 12V wire provides the power
    optical lnb - Google Search
  7. tmsjns
    tmsjns
    Aug 2, 2012
    So that would need to be plugged into mains whoch i dont have down near the dish, Could i use a low quality coax to carry the power supply and then send the signal back down an optical cable?
  8. tmsjns
    tmsjns
    Aug 2, 2012
    would i only need one fibre optical cable to the virtual splitter or wpuld j need two seperate cables as i have sky+?
    Sorry about all the questions im new to this! and thanks for the help!
  9. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
    The signal problem isn't just about signal loss but dispersion (smearing) which optical seems to handle much better than coax.
    For example this company supply ready made optical leads up to 200m:
    Fibre Optics
    You may need to run a higher supply voltage (e.g. 48V) over power cable then regulate down to 12V near the dish.
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Just one. You will also need a new dish if you have a Sky Minidish as the lnb is a non standard size (it's a smaller diameter than a standard 40mm one). It won't be cheap but neither is 360 metres of WF125.
  11. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
  12. tmsjns
    tmsjns
    Aug 2, 2012
    the sky guy said he would give me a zone 2 dish would that be conpatible with a optical lnb?
    Its is quite expensive but around that same price as wf125, im guessig the optical would eb more reliable?
  13. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
    But coax cable still leaves the dispersion risk at that distance.
    I used SDI cable for large scale distribution and that was rated for up to 100m.
  14. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    No the lnb fittings are the same and the oval shape of the dish requires a lnb with the correct shape feedhorn.
    Guessing here (Trollslayer will have a better idea) a 54/60cm round dish should do the job.
    eg
    Satellite dishes. Transparent satellite dishes. Sky dish, freesat dish, mobile dish, Large satellite dishes 54cm - 4.5m. Prime focus. Fixed satellite dishes, Low prices. UK.
    The optical solution will also allow you to add extra receivers should you want more than 1 satellite box.
  15. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
    Dish size is based on location, looking at signal strength maps Wales is within the 54cm area, in fact within 40cm:
    Dish Size Guide
    Maplin stock an adapter to fit a standard LNB:
    SKY LNB Adaptor Clip | Maplin
    One minor point - if it's on a mountain side make sure it has a solid mount!
  16. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    You just need a thin copper insulated wire run alongside the optical fibre. The current required is quite small but as Trollslayer says voltage drop might be an issue. Very simple to fit a DC voltage regulator at the dish end and use a higher voltage at the other end. A 12V DC regulator chip is a standard item.
    L78S12CV 2A Positive Fixed Voltage Regulator | Maplin
  17. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Won't the feedhorn shape be an issue ?
  18. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
  19. tmsjns
    tmsjns
    Aug 2, 2012
    on so im thinking along the lines of an optical lnb would i need a different dish for that even if its a "universal lnb"?
  20. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
    Check with the guy supplying the dish?
  21. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Universal doesn't mean it will fit any dish, it means it's capable of receiving signals from the whole Ku band. To do this a conventional lnb has to operate in one of 4 modes (it's switched by the tuner).
    See
    LNB mysteries explained - part 1
    Note the notes on the specific shape of a skydish and the associated lnb required.
  22. tmsjns
    tmsjns
    Aug 2, 2012
    it would be a standard sky issued zone 2 dish does that help?
  23. tmsjns
    tmsjns
    Aug 2, 2012
    another question, would a quatro virtual conveter work to a single sky+ box? or would it have to be a quad virtual conveter
  24. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Read the notes at the link. The optical lnb will be a standard 40mm collar designed to work with a dish that looks round from the offset lnb location. You can bodge such a lnb onto a Sky dish but it won't work as well as it should, it could for instance pick up unwanted interference as it looks past the Sky dish edges.
    The Maplin adaptor isn't cheap (£12.00) and a Triax 54/60 cm dish only costs about £30.00 or so. The larger dish will give you more bad weather margin (I guess you get plenty of this in Wales). If it was me I would buy the proper dish.
  25. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Best to seek advice from the supplier of the kit. They should be able to advise exactly what you need.
  26. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,066
    Poole
    +10,917
    Good idea.
  27. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Good news
    Fibre satellite distribution - Wikipedia, the free encyclopedia
  28. tmsjns
    tmsjns
    Aug 2, 2012
    ok so im going for a 60cm dish with optical lnb then use the old coax cables to power the lnb but i cant get my head round where i would plug the coax into to run the power for the lnb from? did that make sense?
    then a attenuator a quad virtual converter and coax lines to the sky box, all speted except the power for he lnb, Any ideas on that?
  29. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    A power supply with a f connector output is supplied with the lnb according to the blurb. Presumably you just need a barrel connector to connect the power supply output to the cable end you are sending the power from. (You only need one cable).
    According to this picture you get the barrel connector as well
    Optical lnb power supply - Google Search
  30. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Provided that your coaxial cable is copper-cored and not steel-cored, the voltage drop will be tolerable. Be sure to waterproof the connection to avoid electrolytic corrosion.
