Husoi
Hello guys,
new member here so go easy on me
I have a Lansing Altec (archaic system) computer sound system that has been laying around the garage doing nothing more than gathering dust.
Also a Pioneer dvd player surround system that pretty much the only thing isn't doing is getting dust but haven't use it for over 5 years.
Being a diy enthusiast I'm planning to use the speakers from the above and make a bluetooth system where I can connect the phone.
The speakers I have are:
(surround system)
5 - 70mm 5ohm
1 - 120mm 5 ohm
(Lansing Altec system (LA))
2 - 80mm 4 ohm speakers
1 170mm 4 ohm speaker
My plan is to create a wooden box large enough to accommodate the LA speakers as they are of very good quality
add 2 or 4 of the 70mm with a tweeter filter to enhance the high frequency.
Use the 170mm as bass, but for this to work properly I will need to get another 170mm speaker.
Here is where I will need your help.
Can anybody point me to a place where I can get one of them?
I know it will be impossible to get an exact match but something near enough would do me.
Thank you for reading and really appreciate any help I can get
(surround system)
5 - 70mm 5ohm
1 - 120mm 5 ohm
