1700mah vs 2000mah
Discussion in 'Photography Forums' started by d_devani, Feb 11, 2003.
  1. d_devani
    d_devani
    Is the difference between these that much, cause I can get the 1700mah with charger for £8 but the
    2000mah with charger is costing around £35
    Thats a big price difference.......
  2. tomson
    tomson
    Jul 19, 2000
    1,922
    Berk'amsted
    +186
    I mentioned in a different thread that i've seen a great improvement when using 2000mah - they last a great deal longer.
    As for the price - if 35quid is the best you can find then i'd go for 1700s.
    Personally bought a cheap Uniross quick charger for about 12quid and a few sets of Panasonic 2000mah batteries (£6 upwards).
    Just notices 7dayshop are doing a charger and a 4 pack of 2000s for £17.99 here but i'm guessing you still need them sooner than they can deliver.
  3. d_devani
    d_devani
    Thanx for that now i am really gutted:suicide:
    I think i will settle for some 1800mah for the time being and upgrade later if i need to
