17" widescreen or 20"
Discussion in 'LCD & LED LCD TVs Forum' started by jtfab75, Mar 13, 2005.
Tags:
  1. jtfab75
    jtfab75
    Jul 13, 2004
    813
    BRADFORD
    +10
    not sure what size to get for my bedroom. i currently have a 20"crt but want a lcd tv. will it be better if i stick to 20" or go for 17" widescreen tv ??
    and if so what 20" shall i buy?
    thanks
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,808
    Somewhere in South Yorkshire
    +6,416
    Well, the question is - do you want widescreen?
    17 inch WS is much smaller than your current set (which will be about 18.5 inch viewable), but, if used for 4x3 material, properly shaped, is even smaller still.
    Virtually all the 20 inch 4x3 sets are very low resolution (640x480) screens. Some say this gives them a CRT-like "look". Others say it degrades the signal. Both statements are true.
    You DO want widescreen (IMO) if you intend to watch DVDs, and/or you can satisfactorily receive freeview (which you should then go ahead and do) and/or you have a $ky digital feed to this room. This is more future proof.
    To maintain approximately the same screen height (which is the better measure of "size") you should go for 22 inch widescreen.
  3. treefrog
    treefrog
    Aug 27, 2003
    423
    +14
    I too am looking for an LCD TV for the bedroom to replace my 15" portable. I tried the Sony 23" model but found it a bit too overpowering for the bedroom.
    The 17" on the other hand looks a little too small and is not much of a step up from what I already have.
    When reading a monthly magazine yesterday I came accross the KLVS19A10 (23" model shown but comes in 19".Theres a PDF manual on the site) which is soon to be released in UK. I might be wrong but I've never come accross a 19" widescreen LCD TV before so I think this could be the perfect one for me. According to the spec and the magazine its also HDMI compatible.
  4. treefrog
    treefrog
    Aug 27, 2003
    423
    +14
  5. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    Dell also do a 19" WS TV
    Dell W1900
    Keep an eye out for offers, they recently had it at something like £540
  6. jon2099
    jon2099
    Jun 4, 2003
    183
    Hampshire
    +4
    Dell launched the W1900 a few months ago, which is 19" widescreen and has DVI-HDCP. Specs are pretty decent apart from the 25ms response time.
