17" TFT (DVI)
Discussion in 'Desktop & Laptop Computers Forum' started by danjaq, Apr 25, 2005.
  1. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Suggestions are needed please! I am returning my Acer AL1714 as I'm not THAT impressed with display quality and thought DVI would be more future-proof.
    So, I would be appreciative if someone could suggest a suitable (not mega expensive) DVI-compatible card and, of course, a 17" monitor. I have been ploughing through eBuyer, Savastore and looking at reviews etc, but it would be nice to have a helping-hand!
    Thanks!
  2. mjn
    mjn
    May 24, 2001
    22,114
    Herts, England
    +9,868
    I'm using a Iiyama E431 which is very good.
  3. robbster
    robbster
    Jul 20, 2003
    394
    +13
    I bought the iiyama e435s a few months ago when pcworld/dixons had them on offer. Absolutely stunning screen with good brightness, crisp picture, DVI and a 10ms response rate so perfect for gaming too. Only thing that lets it down is the rubbish speakers that are built into it but are ok for windows clicks and sounds I guess. I've just had a look on ebuyer and they dont seem to have them in stock at the moment although they had them a few weeks ago so maybe they have sold out. Pcworld claim to have them still though, not my favorite place to shop but not a bad price http://www.pcworld.co.uk/martprd/st...&sku=141357&category_oid=-9834&fm=0&sm=5&tm=1
  4. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Okay, it is only 350:1 (like my AL1714) and thought that was a little on the low spec. How do you rate DVI mate?
  5. robbster
    robbster
    Jul 20, 2003
    394
    +13
    Is 350-1 low on spec? I'm not too sure to be honest, all I know is it looks a lot clearer and brighter than the majority of monitors out there at a similar price range. DVI does improve the pic a little over the VGA although it isn't much really.
  6. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    I used to own an Iiyama E431S. Good picture, good reviews and a good price. Of course I succumbed to the widescreen bug but that's a different story. You may want something with faster pixel time but you haven't provided a price range or usage. If you take a look at:
    http://www.pcpro.co.uk/shopper/labs/208/lcd-monitors/products.html
    They've reviewed a wide range of TFTs and the Relisys TL795-RU comes pretty highly recommended so that might be worth a look. And:
    http://www.pcpro.co.uk/labs/126/17in-tft-monitors/products.html
    Is a roundup of 17 inch TFTs from February for all price ranges. The Relisys also scores highly in this test and at ~£139 is good value if you're on a budget.
  7. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Thanks, been to those sites before and had noted the Sharp one already. My budget would encompass up to £250 tops and then there is the matter of a DVi-graphics card....sooo many to chose and I have no idea! Help!!
  8. SimonInd
    SimonInd
    May 9, 2001
    209
    London
  9. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    I have a iiyama E431S and its got good reviews and a great pic. The only downer is its dropped a £100 in price since I bought it 9 months ago. :(
    A good bargain for anyone looking for a new LCD screen. BTW I use DVI and the difference between VGA is noticable. Well worth the cash. :)
  10. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Thanks 'SimonInd' and 'Razor'. It is a bloody nightmare weighing up the pros and cons of all the different types of TFTs out there. I look at the reviews on eBuyer and Savastore and then places like PC Pro and I am all over the place. All I know is that my AL1714 (non-DVI version) is okay but for the money I should have bought higher spec. Afterall I do not want to replace it for a fair few years.
    I will probably chose one of the ones from the PC Pro list, now it is just a matter of deciding which one of the top rated ones to get. Is the main price difference between those ones on PC Pro, just because of the brand names?
  11. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    I bought the iiyama on the strength of a review in pc pro, in fact iiyama have always had an excellent rep when it comes to monitors. The iiyama also has a good response time, essential for playing gams.
