17 minute bug woes
Discussion in 'Satellite TV, Sky TV & FreeSat' started by gilesm, Feb 24, 2005.
  1. gilesm
    gilesm
    Aug 29, 2002
    179
    UK
    Hi all, I've got a series 1 Sky + box that I upgraded about 6 months with a 250Gb Maxtor harddrive. Generally everything has been ok, except twice now.
    The first time (before Christmas) I was watching top gear recorded with about 65% free, and got about 45 minutes through and wanted to skip back, so went back 30* speed, and hey presto found my self at the 17 minute marker immediately. Tried to fastforward ok at 12*, but then went to 30* and again back to the 17 minute marker. I could watch it ok, just not fast forward or rewind at top speed. This is just an annoyance.
    Then the other night went to watch Get Carter I recorded at Christmas. It was recorded with 45% free. Watched this fine for about 45 minutes (dad comes home to party and kicks every one out), and then it froze completely, rewinding took me back to 17 minutes, fast forwarding at slow speed was ok, until exactly the same point - the timer at the bottom constantly read 17 minutes.
    Now I've checked other recordings and they're ok, which is really odd, thought I would get to a point on the disk and that would be it. Anyway is this expected behavoir.
    I know there's nothing I can do about it, but the Get Carter incident was more than annoyance - and I've never seen it before so I've no idea what happens still !!!! Have to go and get it on DVD.
  2. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Hello,
    My V1 box does a similar thing occasionally.
    The only thing to do is delete all of the recordings that have the 17 minute bug and carry on.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    19,085
    White Hart Lane
    +5,147
    I normally do a housekeeping and that sorts it out.Only had it once and that was about a year ago.
  4. gilesm
    gilesm
    Aug 29, 2002
    179
    UK
    Housekeeping? Whats that? Is it a Sky + function? Does it go through and look for bad recordings, or is something you do manually?
  5. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Services 4,0,1,select and it is option 7 (Sky+ planner rebuild)
    Don't look at the screen as you press the buttons for this option, it is a hidden menu.
