17" LCd Monitor or TV - advice please
Discussion in 'LCD & LED LCD TVs Forum' started by del_86, Nov 6, 2004.
Tags:
  1. del_86
    del_86
    Nov 5, 2004
    591
    46
    +238
    :hiya:
    My current crt monitor in the spare room is being used for my pc and xbox.
    I'm currenty looking to upgrade to a 17" lcd, but would like to use it to watch TV, as well as accessing the pc and xbox.
    The question i have is -
    would i be better of with a 17" lcd pc monitor and buy a TV tuner (such as the Aver Media TV box 9) or simpy go for a 17" LCD TV?
    The other thing i have noticed is most LCD TV's come in widescreen format (1200x768) rather than the standard 1200x1024.
    Does this make any difference if using it with a pc or playing xbox games?
    I've done a bit of research on the web, and although i have picked up the basics, there are so many options i'm a tad confused.
    As the LCD would be used to play games, i'm presuming it would need a response time of at least 16ms, or quicker ??
    Any advice would be much appreciated and i would love to here from anyone who has done something similar, or would simply like to recommend a product to buy
  2. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    I'm after the same thing for my son. Instead of TV I'll be using Sky (fed from another location).
    The problem I have at the moment is finding something with the right connections. To be on the safe side I think I'm going to ask the manufacturers what they recommend.
    I'll let you know what I find...
