Quantcast
17" LCD - LG or DMTECH?
richard plumb
both in local comet for £599. LG looked ok, and quite a high res panel.
DMTECH (never heard of it), for same price with integrated DVD player (apprantly progressive scan).
It looked a little soft though, and a bit slow on the update.
Anyone any opinions on either of these screens? Any other options for a 17" widescreen LCD or equivalent (eg larger 4:3). Its for the bedroom, so don't want to spend more than £600-700
S
sponshagga
If youre buying from Comet buy with a credit card that will handle any problems should the item develop a fault. Theyre not too hot on that!
