17" AOC LCD Flat Panel Monitor - Any good?
Discussion in 'LCD & LED LCD TVs' started by Waynej, Dec 11, 2004.
  1. Waynej
    Waynej
    Oct 4, 2004
    6,513
    Wales
    +873
    I was thinking of purchasing this monitor, and thought i'd best post a link to it here first for one of you brainy lot to look at, theres info on it at the below link, not sure what it means, I want it to replace my 15" CRT and plan on buying a TV card so I can play my Xbox through it as well. So what do you lot think then?
    Click Here for Link
    :lease:
  2. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    I've had the previous AOC 17" model for over 2 years, and a 19" model for 18 months, and have had no problems with them.
    I don't use them for games though, and I think they have low refresh rates (25ms ?)
  3. Techno
    Techno
    Nov 20, 2003
    312
    One word - GREAT
    I have one at home and use it for gaming - very good! Also use 2 of these at work side by side with a dual card, they do a great job, especially considering the price!
    Go for it mate
  4. Waynej
    Waynej
    Oct 4, 2004
    6,513
    Wales
    +873
    it says 16 ms response panel, is that the refresh rate. u typed 25 ms, is that what it should be for games or is that what u have?
  5. Waynej
    Waynej
    Oct 4, 2004
    6,513
    Wales
    +873
    Sounds promising, I'll wait for a few more replies I think, it seems to have gotten a mixed reaction so far. Also if someone could recommend a good TV card that will enable me to connect my Xbox to it via scart or component, that would be great.
    I'm planning to build a new system, and fancy sorting myself out with a decent computer, I'm just unsure about these flat panel's, I wanna make sure im getting a good one at a good price, I'm more used to the standard CRT's.
    Anyway, thanks for any help :thumbsup:
  6. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    16ms is better than 25, so should be good enough for fast motion.
    I paid £450 for my 17" 2 years ago, so you're getting a good screen at an excellent price.
    I've ordered from pcnextday too, and would recommend them
  7. Waynej
    Waynej
    Oct 4, 2004
    6,513
    Wales
    +873
    Right OK, I'm gonna order it then. Thanks for the advice. :smoke:
