17 - 23 inch component LCD's
Discussion in 'LCD & LED LCD TVs Forum' started by phillipt, Sep 5, 2004.
Tags:
  1. phillipt
    phillipt
    Just wondering if anyone can tell me any LCDs that have component inputs between the 17" - 23" size. I'm looking for an LCD for my bedroom and as I own a component out DVD player would quite like to make use of it!
    Also would this make a huge difference using component if I'm only using a small screen in a bedroom or is it worth saving money and buying an LCD without component inputs.
    Tim
  2. jon2099
    jon2099
    Jun 4, 2003
    183
    Hampshire
    +4
    I've been checking out 17" panels mostly, the following models I've found have component inputs:
    Relisys RLT1720
    Goodmans/Bush/Akai/Medion 17" (also has RGB SCART), also the 23" version (I think)
    Hyundai WTP-17 (also has RGB SCART)
    Hitachi 17LD4200
    Philips 170T4FS (seems to be designed for the Asian market but eBuyer seem to have it)
    Dell W1700 (also has DVI-D)
    The Goodmans, Hitachi and Dell support 480p (NTSC progressive), the Hyundai and Philips supports 576p as well (PAL progressive). The Dell, Hitachi and Philips also support 720p and 1080i.
