17-20" LCD TV up to £450??????????
Discussion in 'LCD & LED LCD TVs Forum' started by eldudereno, Jul 27, 2005.
Tags:
  1. eldudereno
    eldudereno
    Jul 27, 2005
    83
    Newcastle, N.East
    +5
    Hi all
    Need to replace my bedroom tv which went off this morning asap...Have been browsing the forums for the last couple of hours but I'm still undecided.
    The Philips 17PF8946 seems good but no one seems to have it in stock.
    Can anyone recommend any others? Is the LCD option my best option?
    ps, I mostly just watch Satellite and the odd dvd...my main priority is picture quality......thanks :)
  2. benwong
    benwong
    Hmmm... for around the £450 you can actually get some decent 26" ones... there's the Samsung LE26R41BD which seems very highly regarded and this can be had for around the £550 mark (if you can stretch to it).
    There's also the 27" Toshiba 27WL56 for around the £500 mark.
    Unless you simply don't have the space to accommodate one, you might want to have a look. They're HD ready too!
    Well, for this size range then yes, LCD would be your best option to save space, however for standard definition broadcasts (ie sky digital broadcasts), LCDs will show you how bad the signal really is. You will notice a lot more compression artifacts etc.
    This is of course, until Sky releases it's HD broadcasts next year!
    Ben
  3. rudy
    rudy
    Jan 2, 2005
    499
    Or Hitachi 26" from RS at 550
    Sharp aquos with the speaker underneath for the same
  4. benwong
    benwong
    Is the 26" Hitachi HD ready?
    I was just wandering cos I've got the 32LD7200.
    Ben
