17/19 inch LCD at 1280x720?!??
Discussion in 'LCD & LED LCD TVs Forum' started by Chris Moore, Apr 27, 2005.
Tags:
  1. Chris Moore
    Chris Moore
    Does anyone know of a Widescreen 17 or 19 inch LCD which can accept a vga input at 1280x720 pixels and display it full screen?
    I have a plasma which is running at this resolution and I want to split the vga signal off to an lcd as well.
    I have tried this using my 17 inch philips LCD, but the LCD will not display the resolution without it going off the edge of the screen. The LCD will display 1280x768 fine.
    Anyone know of one which will work?
    Perhaps the Dell 19 inch model?
    Thanks!
    Chris
  2. Rob1698
    Rob1698
    Most if not all small LCD screens are 15:9 so you have either:
    - missing areas at the edges
    - black borders top and bottom
    - deformed picture
