16ms vs 25ms LCD Response - impact?
Discussion in 'LCD & LED LCD TVs Forum' started by RussLB, Oct 16, 2004.
Tags:
  1. RussLB
    RussLB
    Am after a 30" LCD - my other half can get me a Relisys 30" for around £1000, but it has a response time of 25ms - am I likely to notice this? Should I spend a bit more and try a different maufacturer with a 16ms response time? I want to be able to watch DVDs and the usual TV stuff on it.
    Russ
  2. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    You can get a 32" Toshiba for £1238, which I think has a response time of 10ms....or a 30" for £1090.
    Imo, it would be worth spending the little bit extra for a larger screen, and a good brand.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    All down to the individual, but I imagine even if you didn't notice at first, you would eventually... LCDs aren't the best things to hold back on in the money department.
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Russ
    50Hz PAL requires at least a 20ms response rate
    60Hz NTSC requires at least a 16ms response rate
    It looks like one of the sets meets this criteria, the other doesn't. So I would say that the Relsys would definately exhibit motion blur, the 16ms one unlikely to. Or is this too simplistic a view?
    -Ian
  5. RussLB
    RussLB
    Thanks for the info - am defo going to look around for a 16ms one now.
    What are peoples thoughts on the Sharp Aquos LC30HV4E (30") - Richer Sounds have it for £1499....
    Russ
  6. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    I was down there today and it was £1599 - I did manage to find it on the web for (IIRC) £1,420ish but I can't for the hell of me find the URL at the moment.
    Phil
  7. flangemonkey
    flangemonkey
    Nov 27, 2003
    375
    28
    +58
