160g Hard Drive
Discussion in 'Computer Components' started by keelby1, Jun 28, 2003.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,189
    38
    Grimsby
    +14
    I'm looking at getting a Samsung 1604N. For £104 at www.savastore.com it seems a bit of a bargain
    Apparently its as quiet as a Seagate Barracuder VS.
    Can anyone forsee any problems using this in my hcpc which I'm in the process of getting built?
  2. TEK
    TEK
    Should be ok. One word of warning though - if you are going to have a single partition larger than 137gb then for god sake read this:
    http://www.samsung.com/Products/HardDiskDrive/support/faqs/137GB-barrier.htm
    I had a 200gb Maxtor running on XP SP1 and it all looked fine and was happily adding stuff. Then as soon as I hit 137gb it trashed and i lost everything because I didn't run a little 64k "large drive enabler" utility... one of the downsides in buying OEM :(
    So either partition it up or read up :)
  3. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    The 120GB drive is better value. ~ £0.60/GB vs £0.65/GB.
  4. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    but does Samsung make good harddrives ?
    There has got to be a reason why they are cheaper than every other HD. If they are anything like IBM drives, i would stay well away...
  5. keelby1
    keelby1
    Dec 11, 2002
    1,189
    38
    Grimsby
    +14
    Its got good reviews
    I've just ordered a 160gb. i would have had to wait for 2-3 weeks for the 120gb
    I'll keep you posted as to how I get on
    Thanks for the help
