16" Freeview TV Wanted!
Discussion in 'Freeview & YouView' started by Julian Brown, Mar 4, 2013.
  1. Julian Brown
    Julian Brown
    Jun 8, 2005
    303
    Stroud, Gloucestershire, U.K.
    +4
    I need to buy a 16" TV with built in Freeview for our kitchen otherwise a divorce will be imminent!
    I have trawled the internet and every suitable candidate I have come across has been marked "out of stock" or "no longer available".
    Can anyone recommend a supplier of 16" Freeview TVs please who actually has them in stock!
    Many thanks in advance.
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    16" is a very unusual size of screen so it is not surprising that you have difficulty finding one. There was a time when a number of cheap small flat screen TVs used panels intended for computer monitors, hence the odd sizes. That no longer seems to be the case. There is a market for small screens within the caravan/camping market. Unusual brand names, but close to what you want. For example:
    Meos 15.4" HD Ready Freeview TV + DVD Player - 12v-tv - We Do Digital
    You may need a 12V power supply source to run some of these. Other screens can be found in the lorry-cab market.
  3. 961
    961
    Oct 13, 2006
    4,675
    Berwickshire
    +667
  4. Julian Brown
    Julian Brown
    Jun 8, 2005
    303
    +4
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,135
    +7,061
    I strongly suggest you check on that.
    The dimensional differences between a 16 and 19" diagonal screen amount to very little difference in the finished product.and it would increase your options significantly.
  6. luggsie
    luggsie
    Aug 18, 2004
    199
    South East
    +8
    go to amazon.co.uk and search for "alba tv 16 inch".
    luggsie
  7. Julian Brown
    Julian Brown
    Jun 8, 2005
    303
    +4
    The only 16" Albas available on Amazon are either a combi which I don't need or a pink one which I don't want. Standard Freeview black 16" are all "unavailable".
  8. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,691
    Somewhere in South Yorkshire
    +6,262
    I saw a 16in TV in my local Currys yesterday. (Not that I would recommend Curry's or any part of DSG as a virtuous retailer - but they are what they are and they have what you want.....)
  9. 961
    961
    Oct 13, 2006
    4,675
    Berwickshire
    +667
    A factor you need to consider is quality of picture and sound for this new tv
    I've not seen a 16" job which does the business, whereas the number of good quality 19" sets at reasonable prices is obvious from a trawl of the net or a visit to Richer Sounds
    As the MOD says the actual increase in physical dimensions between 16" and 19" is tiny
  10. Julian Brown
    Julian Brown
    Jun 8, 2005
    303
    +4
    Please believe me when I say that our new tiny kitchen cannot cope with anything larger than a 16".
    Picture/sound quality is not of major importance as the TV would only be switched on so that people using the kitchen do not miss any programmes they're following. It will not be used much at all. I have a 42" LG in the sitting room for serious viewing!
  11. John
    John
    Dec 13, 2002
    11,624
    +3,290
    19 inch in the corner of my kitchen. Sits nicely in a corner is only 18in across and from the corner to the front only 12in out.
    I can't see how a 16in would take up much more space, but if you say it won't fit, then I guess it won't fit :)
  12. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,135
    +7,061
    Two 16 inch TV's available from John lewis:
    Here and here
    The first one says its an online exclusive , not available in the shops .. yet my attention was drawn to it in a JL shop today.
  13. lbear
    lbear
    Mar 9, 2010
    2,117
    83
    +337
    Comparing the dimensions of the Linsar 16in and a Samsung 19in from Richer Sounds, the difference in width appears to be about 2 inches. One solution might be to wall mount a slightly larger set. Do you have room to do that?
