16:9 widescreen or 4:3 screen?
Discussion in 'Projectors, Screens & Video Processors' started by iMan, Nov 22, 2003.
  1. iMan
    iMan
    Mar 30, 2003
    34
    I am about to purchase a Mitsubishi XD300U DLP projector that has one native 4:3 chip. Should I buy a 4:3 screen or a 16:9 widescreen screen. All my DVD movies are 16:9 widescreen so with the projector playing these widescreen movies, I assume there will be black bands (letterbox) at top and bottom, or part of the 4:3 chip won't get used?
    If I get a 4:3 screen will that mean I have lots of extra waist at top and bottom.
    Your advice desperately needed here as I don't want to spend £450 on the wrong Draper screen with the incorect aspect ratio.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Best reply I can think of is to point you to ProjectorCentral's article which details the issues to consider far better than I can. :)
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,181
    UK.
    +2,722
    If you only watch 16:9 stuff like me (I have a 4:3 HT1000), then a 4:3 screen will have some slight light spill of the unused area showing above and below the 16:9 image. Having a darker area above and below a 16:9 screen will hide this, and improve apparent contrast. I personaly think this looks better too.
    I only watch movies, so normal tv stuff should always be smaller imho - other wise Coronation St will have a bigger visual impact than the latest blockbuster. The few 4:3 films I have are normaly shown within the 16:9 area, and for me this is a compromise I'm willing to make, as they aren't blockbusters (Laurel and Hardy for example. :) ).
    That's just my opinion of course, and others will disagree, especialy if they want to use the pj for sports programs.
    Gary.
  4. iMan
    iMan
    Mar 30, 2003
    34
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,181
    UK.
    +2,722
    Well, a fixed 16:9 screen will have an even black border all round (aprox 2"), and if it's a pull down or electric screen, it'll have a black border, plus a larger black area above due to how far down it will have to travel.
    Here's a link for a motorised 4:3 screen with a top black 'border' (can't remember the proper name for it right now). A 16:9 would be similar.
    http://www.stewartfilm.com/engineering_specifications/modela.html
    HTH
    Gary.
  6. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    I used a 16:9 fixed screen for a year with a 4:3 Pj, and as I think Gary's getting at, it'll really depend how fussy you are - with 16:9 dvd's (and similar ratios) it means a foot at the top and bottom the picture will be 'beamed' above and below your screen, respectively.
    However, the beaming above and below the 16:9 screen is 'black light' so if you have a dark surrounding wall this isn't much of any issue (again, depending how fussy you are!).
  7. Geoffc10
    Geoffc10
    same here, i have a 4:3 chip pj and 16:9 fixed screen. I put velvet curtains round the whole screen, so unless you get really dark scenes you cant see the 4:3 panel spill over. The only bugbear is watching 4:3 dvds as streched 16:9 picture, but i use natural wide on my tele that distorts the edges, i dont mind, i can live with it. i only have a few 4:3 dvds, most i watch on my ps2 and 14" tele.they tend to have a slight jump in picture which is magnified on a 5ft screen, even could tell on a 28 " widescreen tele!
