16/9 or 4/3
Discussion in 'Projectors, Screens & Video Processors' started by Ricky27, Apr 7, 2002.
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    I am considering getting a projector and have been looking at the ae100 and sony hs1
    Im new to projectors and want to know what would be best as i watch lots of 4;3 tv aswell as widescreen dvds.
    Would the panny display a 4;3 image on a 4;3 screen?
    Any advice would be appreciated.
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    The Panny will work like a widescreen TV. The biggest picture will be from widescreen sources like DVD. Any 4:3 images will be smaller, they will fill the height of a 16:9 screen, but leave unused bars to the left and right of the image.
    Projectors like the Sony HS-1 that use 4:3 shaped LCD panels will work like a 4:3 TV. Their largest image will be from 4:3 material. Widescreen films will fill the 4:3 screen width, but not the height.
    Regards
  3. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    as well as a proper 4:3 mode with black bars left & right, the Panasonic pj also has a stretch mode to let you use the full 16:9 screen size for 4:3 material.
    this is what I match all 4:3 material with on my Pansonic TV,
    and its pretty good on most things... will be doing exactly the
    same when I get my projector soon.
    as is, you list a Pace sky digibox in your equipment...
    set this to proper 16:9 and you will find that a large percentage of BBC, ITV, C4 & C5 tv is now broadcast in widescreen.
