16:9 fixed screens
Discussion in 'Projectors, Screens & Video Processors' started by StephenR, Apr 13, 2003.
  1. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    I have been searching various web sites for a 16:9 screen with 100" diagonal which can be fixed to the wall, but I can't seem to find any. I don't want to pay ££££ for a custom made screen, and I thought this would be a fairly standard size. I plan to use it with a Panasonic AE300. Any ideas on where to look?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Draper, OWL, Stewart, VuTec.....Or buy some material from Harkness Hall and make yourself a frame. Not sure if they all do 100" diagonal as standard but someone like VuTec will make to that size and charge for nearest larger screen.
    Gordon
  3. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Thanks. The screens I've seen seem a bit pricey. Anyway, it looks like I'm going to have to have a retractable screen as I need to mount it about 2 ft away from the wall to give me the screen size I need for the throw distance I have.
  4. Jonny1973
    Jonny1973
    Screens measurements are usually advertised by the width measurement.
    80" seems to be fairly common which gives a 92" 16:9 diagonal (I think). I have a Da-Lite Model B 80" 16:9 from http://walterstewart.com/uk2shop.htm . It cost £212.
    It's a long time since i did pythag at school.
