16/24 grit sanding discs (or paper) 15" wide
spoonuk
Does anyone have a clue where to get 16 or 24 grit sanding paper discs 15" wide?
I don't mind cutting the discs myself but can't find wide enough sanding paper :(
Any help would be much appreciated.
spoonuk
Presumably the tool manufacturer will have them?
They do but they are expensive as hell so looking for some 3rd party ones or making my own...
sparky10
Hi, did some searching and there are plenty of companies in the U.S that sell 15 inch diameter sanding discs as you probably already know, whether or not they will ship overseas is another matter and not sure if it would be cost effective?
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
