15m DVI cable - supplier says it won't work???
Discussion in 'Projectors, Screens & Video Processors' started by Bada Bing, Mar 22, 2006.
  1. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Just tried to order a 15m DVI cable for my Hitachi PJ-TX100 (to get ready for Sky HD) and the supplier has said they don't think the cable will function over that length. They've suggested an optical fibre cable, but how on earth is that going to work? :confused:
  2. teched whfsv
    teched whfsv
    Mar 12, 2002
    45
    Like this:
    http://www.dtrovision.com/oc.htm
  3. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    Isnt about 10mtrs the limit for digital cables?
  4. teched whfsv
    teched whfsv
    Mar 12, 2002
    45
    Doesn't seem to create too many problems with undersea fibre optic telecomms cables!
    :D
  5. oblivion_6
    oblivion_6
    Mar 17, 2006
    140
    Glasgow
    +3
    15 Meters seems one hell of a distance to move a signal along, Im guessing why it wont work is due to the fact that the signal would fade so far along the line, is it not possible to put a signal booster midway or something?
    I tried this in my last house using an s-video cable from the pc to the monitor, it was about a 10meter run and without the booster I noticed the signal was weaker and the output poor.
    I think if i remember it was maplins i got the booster from.
  6. puc
    puc
    Jun 17, 2002
    167
    +4
    thats nonsense, we have a few 20m+ cables here at work feeding up to ceiling projectors, never had any problems. probably top grade cabling tho.
  7. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Wow, thanks for the quick response, everyone. Okay, so if I go for an optical one, what type of connector should I have at each end?
    This is what they're asking. :(
  8. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    DVI though?
  9. teched whfsv
    teched whfsv
    Mar 12, 2002
    45
    As you'll see from the Dtrovision site, it just has standard DVI connectors on each end, and converts to optical at the sending end, and back to electrical at the receiver. Usually powered by the DC supply on the DVI output of whatever's at the sending end - in a very few cases may need an external power supply for the 'sender'.
    BTW, available in the UK from Asheridge Communications and Keene Electronics
  10. Mark_a
    Mark_a
    May 27, 2005
    3,252
    +708
  11. justinh
    justinh
    May 6, 2002
    113
    Slough
    +6
    I have just recently purchased a 15m HDMI to HDMI cable. I was running from a DVI source so got a DVI to HDMI adaptor.
    I read quite a bit and realised this might be pushing HDMI too far. However I went and purchased a BetterCables lead(http://www.bettercables.com/index.asp?PageAction=VIEWPROD&ProdID=8), as it seemed to get consistently good reviews.
    It has worked perfectly. As far as routing it concerns - it is very thick (may be 9mm thick approx) although fairly flexible. Price in UK is about £200. Was worth if for me as a long term investment
    It connects and Oppo 971 DVD player to a Sony HS60 projector. It will eventually go between an AV Amp and the projector, when I purchase one with HDMI switching.
    They do a DVD to DVI equivalent (http://www.bettercables.com/index.asp?PageAction=VIEWPROD&ProdID=22) and HDMI to DVI (http://www.bettercables.com/index.asp?PageAction=VIEWPROD&ProdID=16)
  12. ectoplasm
    ectoplasm
    Jan 7, 2006
    246
    +16
    I'm using a 15m long one of these: http://www.lindy.com/uk/catalog/14/04/02aa/index.php
    Works perfectly at 720p and 1080i between an Oppo and a Hitachi TX200 using a cheap DVI > HDMI adapter off Ebay. Sane pricing as well.
    I'd give one a go first, and if it doesn't work for you Lindy are good with returns. I saved myself over £100 going down this route over more expensive cables (was looking at £150+ Supra and Bettercables previously) ;)
  13. Darko
    Darko
    Apr 13, 2005
    4,220
    Caterham on the hill Surrey
    +223
    I got a 15 m hdmi to hdmi and it works a treat and I got it for £60 from Fleabay so it may be worth a look
  14. sniffer66
    sniffer66
    May 22, 2004
    9,960
    +3,722
    I back the Lindy extra long also, Im using one and have never seen any issues - sparklies etc
  15. EddThompson
    EddThompson
    Feb 28, 2005
    409
    spalding lincolnshire
    +20
    lindy here too, works a treat :)
    edd
  16. Family Guy
    Family Guy
    I think your suppliers are covering their own arses here TBH...I think the DVI/HDMI standard only guarantees sparkly & interference free signals up to 7.5m.
    For the record, I'm using a Lindy 10m DVI cable from a Yamakawa DVD player pushing native res to a Sony HS10...problem free for over a year now...:smoke:
  17. redmax
    redmax
    Sep 13, 2002
    1,079
    ESSEX, UK
    +43
    I am using a 15m cable terminated with DVI one end and HDMI the other.
    It was made by Mark Grant who is a long standing member of these forums.
    The cable is made to the highest quality and works without a single sparklie.
    I actually run the majority of it outside the house and it works fine on my Sim2.
    You can check his web site here:http://www.markgrantcables.co.uk/
    BTW he always looks after fellow forum members.
    Check him out
    :thumbsup:
  18. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    Just to add my two penneth, I'm also using a 15m Lindy DVI to DVI with no problems.
