15m component recommendation?
Discussion in 'Cables & Switches' started by jasper_mccrea, Jun 17, 2005.
  1. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    I'm in need of a component video cable around 15m long. My other video cables are the IXOS XHV704 ones, which are pretty fine, and for the sake of being able to hide it somewhere I'm looking for another fine one. No huge ones for me thanks. IXOS don't make a 15m one, and if they did, it'd probably be real expensive. Can anyone recommend one? For not much more than £50-60?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,570
    The Borders
    +3,029
    jasper mccrea
    The longer the cable run the heavier you want the cable :)
    Thin cable = more resistance!
    VanDamme Red Series Mini 4 core (8.8mm) wired for YUV is a good compromise - though it'll be nearer £115.00.
    Try a couple of the banner adds - you may find what your looking for within the indicated price range.
    Best regards
    Joe
  3. Freddo14
    Freddo14
    May 11, 2005
    27
    3
    I got some component leads recently from
    Heartland Cables
    The website looks a mess and I was dubious at first but its obvious this guy is really serious about his cables, they are really really well made. Shipping to the UK was like $12 and I didnt catch any import tax ( though your milage may vary)
    worth giving it a look anyways.
  4. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    I bought 35ft s-video and component leads from www.bluejeanscable.com
    Good quality cable and reasonable shipping.
