15'8 x 12'4 room £700 budget
Discussion in 'Home Cinema Speakers' started by dan1979, Sep 16, 2004.
  1. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    I currently have a 5 year old Mission Cinema One package (700's, 70c1 and 70's I think it is).
    I am moving and have a loft room which is all nicely done with minimal stuff in it which is 15'8 by 12'4 theres a hatch in the rear corner which means I need the rears to be satellites on the wall as there's no space for a speaker stand.
    Currently have an old Sony STRDB925 amp which I am thinking of upgrading to the Yamaha 750.
    Bearing in mind the speakers I have would it be better to get a whole new set up like the Aegis packages? I quite fancy floorstanders at the front as I want decent stereo, would it be a bad idea to have floorstanders at the front and satellites at the back in terms of balance? Could getting new Mission centre and floorstanders at the front be an option and keeping the current satellite rears?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Yes you could easily get new mission front floorstanders and a centre and keep the rears to save yourself some money. Spend the rest of the moeny saved on a nice new sub :devil:
  3. digisocialist
    digisocialist
    Sep 5, 2004
    480
    Yorkshire
    This is a good question. I've looked at the B&W 600s3's, but could I marry 600s3's at the rear, with say two B&W 303's at the front on stands, or would the difference create an imbalance?
