150 v 300 LED
Discussion in 'Home Cinema Buying & Building' started by swiss_tony, Jan 9, 2012.
  1. swiss_tony
    swiss_tony
    Jul 28, 2007
    3,703
    Gloucester 'mind'
    +184
    Can anyone recommend if 150 LED is sufficient enough to backlight a TV or would I need to bump up to 300?
  2. schford
    schford
    Mar 19, 2006
    285
    28
    Windsor
    +33
    150 is more than enough!
  3. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    Portsmouth, Hampshire, UK
    +166
    If you have an LCD TV with only 1cm gap between the TV rear and the wall, you may find that 150 LED's does not give you enough 'wall-fill'. If the gap is more than 4-5cm then 150 is fine.
