15 Pin - DVI - D
Discussion in 'Cables & Switches' started by PaulTippins, Jan 20, 2005.
  1. PaulTippins
    PaulTippins
    Can I connect a PC using 15 pin VGA cable to a LCD or Plasma using DVI - D input, namely some Samsung Consumer Products?
    If so how??
  2. midiman
    midiman
    Jan 8, 2005
    320
    London
    I think DVD-D is a purely digital input so probably not. I know you can with DVD-A using an adaptor but thats not a lot of good to you. Your best bet is to get a graphics with DVI-D out on it. Even the cheap ones come with them theses days
