happyhiker
Established Member
- Joined
- Jan 3, 2005
- Messages
- 438
- Reaction score
- 27
- Points
- 167
Hi All,
My Plasma and Mounting bracket have just arrived, so I'll be drilling holes tonight. I have a Cabiling question though. I'll be feeding the Plasma via VGA. Keene Electronics do a D Plug face plate, but will I need to gouge out the plaster to lay the cable, or can I drill a hole as far as the wall cavity and feed the cable though, probably with a bit of wire, and save a plasterer coming in?
The house was built in 2004 so conforms to whatever building standards.
I think the wall is plaster board then insulation filler(looks like the stuff you get in lofts) then breeze block then brick. But I'm not 100%.
