15" DIY Build nearly finished
Discussion in 'DIY Speaker & Subwoofer Building' started by Pilgrim123, Jun 17, 2015.
  1. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Hi all
    I have just Purchased a nearly completed sub from the classifieds from Goujam, the original thread was Thinking of going diy | AVForums
    Purchased thread
    https://www.avforums.com/threads/diy-15-subwoofer-90-complete-including-1600w-pro-amp-driver-and-cables.1964041
    I just wanted to start a new tread to show my progression off finishing off this great sub build that Goujam had nearly finished.
    I will update you all along the way and I know Goujam is keen to see the finished project so let's hope I do it justice!!
  2. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Looking forward to seeing the finished item. Especially how you finish it paint or vinyl
  3. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Umm that is the question, I'm still unsure as if I wanted to paint it, it would all need sanding and skimmed and primed. I'm thinking of keeping with your original plan and get it wrapped in black gloss and then it would match my speakers.
  4. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    I think if you have the time paining will give the better result. But it will take a lot of work filling rubbing down and primer. The wrap will still need some prep work but not so much.
  5. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Has anyone got any recommendations on what primer and gloss black to use on plywood???
  6. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Any updates on this yet? Have you managed to try the sub out yet?
  7. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    I have managed to have a little go with the sub and it does sound good. It bangs and sound low! I have attached a few pics below as I have not route red the edges and put the feet on. It's going into my makes body shop next week to get painted' ImageUploadedByAVForums1435248391.818204.jpg ImageUploadedByAVForums1435248406.317806.jpg ImageUploadedByAVForums1435248417.416515.jpg ImageUploadedByAVForums1435248426.148625.jpg
  8. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Looking good getting it painted will make it look really nice you still going gloss black
  9. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Yes the plan is still gloss black to match my other speakers, what and how were you going to put the speaker cloth on the vents for the amp?
  10. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    I was going to make some frames using thin bits of wood. I was looking in wickes near me and they sell strips of different shapes of wood. The plan was to get very thin strips and make a slightly smaller than the whole frame then cover with speaker cloth or any other black cloth. I was going to try a push fit but if that didn't work small magnets could be pushed into the frame and small bits on metal on the sub to hold them in place
  11. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Cheers I'll have a look about
  12. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Did you manage to get the sub painted this week ?
  13. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Not yet, in the same boat as you were very busy at work, but the sanding down is now all done which is good, should get it primed tomorrow all being well!
  14. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Progression has been slow on finishing this project as I have an issue with the rack amp vibrating and rattling!! Any suggestions anyone?
  15. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    What kind of rattling is it? It maybe worth taking the top off the amp to check the power supplies I added to slow the fans down are still in position and they haven't moved in transit.
  16. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    I'll have a look tomorrow, when the sub hits hard you can hear the amp rattling inside!! I'm also going to try and position it in different area of my room as with the anti mode inline it seems to be quieter then before, also this might be an issue with my floor stands over powering the sub
  17. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    I'm thinking of selling my Yamaha 675 and replacing it with a pioneer mode as I think they have more tuning options built in, any thoughts??
  18. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Could it be the amp rattling on the rails have you screwed the amplifier in keeping it right ?
    If you mean its quieter with the antimode in line compared to no antimode this maybe that it has removed a peak on one of the frequencies.
    I'm not sure with the pioneer I've always had audyssey on my amps my latest has xt32 which works well
  19. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Yes they are all screwed down. I'll have a chat with someone at richer sounds and see what they have got
  20. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    Just brought a second 15" driver so time to go dual 15". Got 2 new boxes being made going to carbon vinyl wrap these with an solids Oak top
  21. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    So Second driver brought and arrived today broken [emoji35][emoji35] voice coil gone
  22. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    Nightmare what driver have you gone for ?
  23. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    I found another one the same as you put in, but now need another one, had to new boxes made but now only one sub!!
    Any ideas on 2 different ones for that box size would be much appreciated [emoji4][emoji106]
  24. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
    ImageUploadedByAVForums1473422113.265304.jpg ImageUploadedByAVForums1473422123.514574.jpg
    Boxes have arrived!!
  25. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
  26. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
  27. Pilgrim123
    Pilgrim123
    Sep 9, 2014
    386
    +53
  28. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    Looking great! :thumbsup:
