1366*768 good or bad for pc
Discussion in 'LCD & LED LCD TVs Forum' started by carlo67, Jun 3, 2005.
Tags:
  1. carlo67
    carlo67
  2. WSB
    WSB
    Dec 31, 2004
    358
    +7
    Thats the max resolution you can use- each tv supports several resolutions.
    In fact- I have a Relisys 32" and havent got my PC to display that resolution correctly- I get slight horizontal flickering and a little overlay on the right hand side of my screen. Apparantly it depends on the graphics card but I couldnt get my GeForce 4200i (128mb) or my upgraded Radeon 9600 (256mb) to work- both didnt work in different ways. Anyway- I digress- I've settled for 1280x768 which fills the screen and still looks good- not a one to one pixel mapping but I've given up complaining about it.
  3. Rob1698
    Rob1698
    A 32" screen is not good for normal use of computers.
    At a normal viewing distance you have a much too large screen which you cannot oversee.
    At a good working distance the screen is so far away that you will have difficulty to concentrate on reading text.
    At a normal TV viewing distance the text will be too small to read. Forget about websurfing on the TV.
    You will need two screens. One for watching TV (32" is nice), and one for the PC (where 20" is about the maximum and most people would use 17").
  4. Deku
    Deku
    I've noticed 1360x768 is nearest resolution my gfx card will produce (nvidia fx5200). If you match the panel's native resolution there will be no re-scaling involved, and the quality should be the same as a normal lcd monitor.
  5. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    do pc games look good on a 32" lcd though? as im thinking of hooking a pc to one and a 17" tft monitor for surfing etc?
    what gfx card do u recommend (max of £150)
    cheers
    jason
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    As Rob suggests, 1366x768 is too low a resolution on a 32" display for everyday (non gaming) computing on a PC. My laptop is 1024x768 on a 13" display and is a very comfortable size at 2 ft - equate that to an estimated 15" for a 1366x768 widescreen equivalent. So you are goint to need to sit much further away, pay more for the screen and get no extra real estate to show for the extra dosh.
